Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bad Pool Header WiFi adapter wnda3100
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-12
07:59 AM
2016-03-12
07:59 AM
I recently instsalled Windows 10 and everything works great until I try to connect to the internet using my Netgear WiFi adapter (WNDA3100 Model). When I do within seconds I get a blue screen of death and the message that the cause is a Bad Pool Header. I used a second computer to find Windows 10 drivers for the adapter which I downloaded and installed to the computer. Unfortuately I would up with the same problem. Not sure what to try at this point to fix the problem.
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-03-15
08:18 AM
2016-03-15
08:18 AM
Re: Bad Pool Header WiFi adapter wnda3100
Hi Walt_Mayhew,
Is it WNDA3100v1? if yes, the adapter does not support Windows 10. Please double check the version of the adapter.
Message 2 of 2
Announcements
