- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cant detect 5g network after downloading drivers
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I download the latest driver, all of a sudden my adapter can't detect the 5g network and when I tried deleting the driver the 5g network comes back up. I have tried downloading an older driver but the same problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cant detect 5g network after downloading drivers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't follow.
@DurianS wrote:
....when I tried deleting the driver the 5g network comes back up.
Does that mean that you see 5GHz again when you remove the driver?
I assume that you have checked that the 5 GHz source is still working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you have a faulty modem in your possession. if your tried all the troubleshooting you can ring up netgear technical support and get a case number for a replacement modem then take it back to the retailer where you bought it from and ask for a replacement cause under Australian Consumer Law you have the right to ask for a refund,repair or replacement if the unit in question is Faulty and it doesn't matter how long you've had the unit in yhour pocession as loing as you have the receipt they have to do something about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried updating the modem to the latest firmware vesion 1.0.0.51_1.0.1 to see if that helps and solves your issue, bar that try a full factory reset after you've updated to the latest firmware. I updated my modem to the lastest firmware as soon as i took my modem out of the box and connected the modem up and my 5ghz is working fine! the only problems i'm having with it is the wifi is dropping out on it to frequently and the modem is getting incredibly hot under normal operation which it shouldn't be as technology doesn't like to much heat.
