× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connects with 802.11n not 802.11ac
BeeWall
Guide
I am using a Netgear R6200 router with an A6200 usb adapter on Windows 8 64-bit in the 5GHz band, and it connects using 802.11n. I cannot find any options for using 802.11ac and in the A6200 WiFi Adapter properties I don't even see a reference to 802.11ac.
Does anyone know what I setting I need to change to get 802.11ac?
Message 1 of 13
jmizoguchi
Virtuoso
Re: Connects with 802.11n not 802.11ac
802.11ac only works on 5Ghz
Make sure you are connected on 5Ghz only
Message 2 of 13
BeeWall
Guide
As I mentioned in the original post I am using 5GHz.
Anyone have any ideas?
Message 3 of 13
jmizoguchi
Virtuoso
Did you test at closer range if it is connected at 5Ghz?
Message 4 of 13
BeeWall
Guide
I have tried different locations (same room) and it doesn't change. Only connects using n.
Message 5 of 13
jmizoguchi
Virtuoso
what is the Max Mbps you are getting?...
Message 6 of 13
BeeWall
Guide
About 85 Mbps
Message 7 of 13
Mark_K
Tutor
Try the adaptor in a different PC.
Message 8 of 13
newgolfer
Novice
Message 9 of 13
BeeWall
Guide
I don't have another Win 8 machine to test on. I also looked at the suggested thread and the Enable WMM is checked. Is there a way to turn off 802.11n?...or only allow 802.11ac connections?
Message 10 of 13
jmizoguchi
Virtuoso
All protocol is supported 802.11ac
A/N/AC
You can not change just to accept 802.11AC only
Message 11 of 13
Olegrius
AND?????
I have same problem!!! Win 7 + A6200 + R6300 + 5Ghz = no internet/network access! F... And so do?
Message 12 of 13
jmizoguchi
Virtuoso
Olegrius wrote:
AND?????
don't hijack a thread.
this thread is not internet issues.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 20962 views
  • 3 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
