× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Convert printer to wifi
Eddie365
Follower
Which product do you recommend to convert a Kyocera TA4550ci MFP to a wifi device? Currently it is being used via USB cable in a wifi environment.
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Convert printer to wifi
Hi Eddie365,
NETGEAR USB adapters are compatible with Windows based computers and does not work other devices. If your printer has ethernet port, you can try WNCE3001 or WNCE4004.
Message 2 of 3
All Replies
JamesGL
Master
Hi Eddie365,
Message 2 of 3
JamesGL
Master
Hi Eddie365,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3316 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
