Onekutguy's avatar
Onekutguy
Follower
Jun 06, 2020
FIX: A6210 cannot create wireless hotspot
For those still having this issue, I found a fix that works for me.
Problem
Onboard WiFi disabled.
Netgear A6210 enabled.
No mobile wifi.
The Fix
Onboard wifi ENABLED.
Netgear A6210 ENABLE.
Mobile wifi works.
Basically, the Negear A6210 needs the onboard wife enabled in order to create a wifi hotspot.  Not sure why, but that's what work for me.
No RepliesBe the first to reply
