- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MediatekSw Application Crashes Daily in Reliability Monitor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,can you please help me on this one, I am running the Netgear A6210 USB Adaptor on my Intel based PC. The USB Adaptor MediatekSw Application crashes daily. Do I need this application to be running on the A6210, if so can you suggest a fix for me please. Appreciate any help...thanks garry
Below is the printout of the Problem from the Reliability Monitor
Source
Summary
Stopped working
Date
30/10/2015 8:52 PM
Status
Report sent
Description
Faulting Application Path: C:\Program Files (x86)\NETGEAR\A6210\NetgearSwitchUSB.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: NetgearSwitchUSB.exe
Application Version: 1.0.1.1
Application Timestamp: 54379850
Fault Module Name: StackHash_76b1
Fault Module Version: 10.0.10240.16430
Fault Module Timestamp: 55c599e1
Exception Code: c0000374
Exception Offset: PCH_B9_FROM_ntdll+0x0006919C
OS Version: 10.0.10240.2.0.0.768.101
Locale ID: 3081
Additional Information 1: 76b1
Additional Information 2: 76b1253de6368a34241f1ea1610933cf
Additional Information 3: 7764
Additional Information 4: 7764f006b024e6d5021a39e6b0873691
Extra information about the problem
Bucket ID: 188bf12997809ad65ca5eb270317b63a (107539537085)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MediatekSw Application Crashes Daily in Reliability Monitor
Hi @gnbalbion,
If you have an option for disable it then you may do so. Try to use as well the driver from NETGEAR instead of MediaTek.
http://support.netgear.com/product/A6210
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply, I am using the Netgear Driver, maybe the mediatek came fom the prior installation, I will check further,, thanks
