× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N300 wifi usb adapter wna3100-100ens
Geekmachine
Follower
We have purchased a netgear N300 wifi usb adapter.  We have been unable to get it to run with the software included.  The software is the latest version 2.4.  We tried uninstalling and installing an earlier software version as well.  We have tried everything.  Even plugging it directly into our USB with just the stick itself.  Cannot get the device to be seen on any of our laptops or, our workstations.  We think the product is defective.  We need a replacement.  Can we do this online?
Thanks
Computer geek
Message 1 of 2
JamesGL
Master
Re: N300 wifi usb adapter wna3100-100ens
Hi Geekmachine,
If you have purchased the device recently, you may return it first to the store where you purchased it.
When you plug the device, can you see a light lit up?
Can you check the device manager if you can see the adapter?
Do you get error message when installing it?
Please try to use other drivers.
http://downloadcenter.netgear.com/en/product/WNA3100#searchResults
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3133 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
