× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
N600 WNDA3100v2 connecting to smart tv
Karli86
Follower
I have a Netgear N600 WNDA3100v2 and i would like to use it to set up the internet on my Soniq smart tv. If there is some easy guidelines on this or  any sort of help setting it up that would be much appreciated.
Model: WNDA3100v2|RangeMax Dual Band Wireless-N USB Adapter
Message 1 of 4
Accepted Solutions
JamesGL
Master
Re: N600 WNDA3100v2 connecting to smart tv
Hi Karlo86,
The WNDA3100v2 will only work with Panasonic Viera TV. Please check this KB article.
http://kb.netgear.com/app/answers/detail/a_id/13857/~/using-the-wnda3100v2-to-connect-a-panasonic-vi...
Message 3 of 4
All Replies
TheEther
Guru
Smart TVs generally do not work with USB-based Wi-Fi adapters.  If your Smart TV doesn't have built-in Wi-Fi, then you will need an Ethernet-based Wi-Fi adapter, like the WNCE3001.  A range extender will also work.
Message 2 of 4
JamesGL
Master
Hi Karlo86,
Message 3 of 4
JamesGL
Master
Hi Karlo86,
 We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6818 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
