- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N600 wireless dual band usb adapter - as stand alone wifi extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would like to have stronger wifi signal throughout my home. Was about to purchase a "wifi extender" (the type that plugs into a wall socket), but came across this N600 that I purchased years ago but never installed....don't even remember why I purchased it. Anyway....question is whether this device can be used as a wifi signal extender/amplifier & if so, should it be plugged into my router (Optimum D-Link DIR868L) which has a USB port or into a USB port on my desktop PC (Windows)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N600 wireless dual band usb adapter - as stand alone wifi extender
That's a wifi speed designation, not a device model number. Could be anything. Modem? Router? USB adapter? Wifi extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
WNDA3100
@michaelkenward wrote:
@dds-35 wrote:but came across this N600 that I purchased years ago but never installed....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dds-35 wrote:
WNDA3100
That's a USB adapter. You use it to connect your Windows device to the wifi. It is not use for anything else.
Actually, probably not much use for anything these days.First launched in 2007, it is designed for Windows Vista and XP. Newer versions of the WNDA3100 (2014 for V3) promise to work with Windows 8.1. It is anybody's guess if it will do Windows 10.
