× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Need help connecting to my router homepage
Luxas
Follower
Hello,
I need to reach my router page on my Windows 10 desktop PC but entering the default gateway adress into the search bar like you usually would doesn't work. I suspect my WiFi USB Adapter to be the cause because when I go into Control Panel\Network and Internet\Network and Sharing Center and check the details of the wireless connection I don't seem to get the router description but the WiFi Adapter description. This leads me to believe that the IPv4 default gateway being displayed isn't that of the router but of the WiFi Adapter.
Does anyone have any idea how to solve this and connect to the router homepage? Thanks.
Model: A6210|AC1200 High Gain WiFi USB Adapter
Message 1 of 2
Re: Need help connecting to my router homepage
@Luxas wrote:
Hello,
What is this router?
Can't you get at it using Windows Explorer?
Look at Network Infrastructure and right click the "Gateway" device.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1026 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
