- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NetGear wnda 3100v2 Won't Work Windows 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
THIS IS NOT A REPEAT OF PREVIOUS POSTS THAT I CAN TELL.
I have now installed (and uninstalled) the newest Genie 5 times and the newest stand alone 3 times (and downloaded the files from the Netgear site 3 times). Despite this, I am still showing the old driver version from 2010. (5.100.68.29)
I can tell when my internet is about to go out because my computer starts working really hard for about 30 seconds and then the wireless becomes just intranet and then finally the adapter will disable itself. I have unchecked the box that allows Windows to power off the device every time that I have installed the drivers.
Why does the newest software that says it supports Windows 10 keep installing the old software on my computer?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NetGear wnda 3100v2 Won't Work Windows 10
Hi tbhesswebber,
Please make sure to completely remove the driver of the adapter on your computer. Remove it on programs and also remove the NETGEAR folder under program files. Remove as well the Genie. Reinstall the adapter's driver for windows 10 after removing the previous programs and drivers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried that and it worked!! Finally have the answer after 4 months! Thanks!
During the install I did get an "error 0x00000??" but I can't remember the last two digits and I am not uninstalling again unless my connection drops again in the next day or two.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far so good! I think we can count this as solved!
