- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear A6210 Wireless Adapter Ping jumps
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear A6210 Wireless Adapter that I got because my desktop computer does not have a wireless adapter. I installed the drivers and It worked good but when I play csgo my ping is fine until some time later when it goes way up high and I start lagging. But that only lasts for a couple of seconds and then i'm back to normal. I have tried to reinstall diffrent versions of the drivers but it happens with all of them. I have even tried changing the wireless channel on my router.
I don't use the genie. Just the standalone driver. (It does also happen with the genie).
Is there any way to fix this? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear A6210 Wireless Adapter Ping jumps
Tried both bands? Tried different channel?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes both bands and diffrent channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have USB2 port as well as USB 3 on your desk top? Then try both ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have now tried 2 diffrent USB 3 and 2 diffrent USB 2 and the same thing happens...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wonder if you are using Genie? If yes, completely deinstall the software suite(Genie + driver) then just try the free standing driver only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't use the Genie. And I have tried re installing the drivers multible times. Even older versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me, last thing is whether this problem happens at certain time of day. Usually in the evening 'net traffic is busier if there not enough
bandwidth availabe this kinda thing can happen. Iam in a way lucky not having those problems. Run speed test at different times of the day. Is it steady at full speed you supposes to get from your ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried running speedtest a few times some days ago at diffrent times. They are nearly completaly same. And I did use a powerline before and it was completely stady. So I belive it's the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like it then. When I do ping test I pick known target like www.yahoo.com same with speed test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have to buy a new one.... ?
