× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear A7000 unable to detect 5G networks
aa89123698
When I first time got the device it can connect to the 5G network, but after 2 weeks the 5G network suddenly disappeared. I also tried reinstalling it many times, it did not help. Only this device cannot connect to the 5G network, all other devices I had is able to. This is on a Windows 10 PC. Please help, Thank You.
Model: A7000|NIGHTHAWK AC1900 WIFI USB Adapter
Message 1 of 6
Blanca_O
NETGEAR Moderator
Re: Netgear A7000 unable to detect 5G networks
Hi aa89123698
Welcome to NETGEAR Community!
May we please know the brand and model number of your router? Please try changing the router 5GHz WiFi channel.
Blanca
Community Team
Message 2 of 6
aa89123698
 I use verizon for the router and the model number is WCB6200Q.
Message 3 of 6
Blanca_O
NETGEAR Moderator
Hi @aa89123698
Do you know how to access your router UI? Please try changing the router 5GHz WiFi channel.
Blanca
Community Team
Message 4 of 6
aa89123698
 I never heard of the term 'router UI' before, is it like the area that you login to your router? If not can you explain what it is? And also, what do you mean by changing the router 5GHz WiFi channel?
Message 5 of 6
Blanca_O
NETGEAR Moderator
Hi @aa89123698
Router UI (User Interface) is where you can change the settings of your router. If you are not familiar with it, I suggest to call your ISP and seek assistance of how to change the 5GHz WiFi channel.
Blanca
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3750 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
