× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk stopped working?
slayerx17
Follower
I bought netgear nighthawk ac1900 wifi usb adapter 6 months ago because my laptop only recognize 2.4 ghz wifi. Everything worked perfectly when i installed my new adapter (5ghz and 1300mbs compared to 2.4ghz and 144mbs) till yesterday when its only 2.4ghz. Got both enabled in my wifi settings, wasnt changing nothing it just stopped recognize 5ghz wifi. (when i disable 2.4 it cant find my network). Please help
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Netgear Nighthawk stopped working?
Hi slayerx17,
Welcome to NETGEAR Community!
Does the issue still exist?
Please uninstall and install the stand-alone driver version. You can also try changing the router 5GHz channel and check if it will resolve the issue.
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 697 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
