Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Wifi Adapter Software
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-19
02:05 PM
2016-06-19
02:05 PM
What is the difference between Netgear A6210_v1_0_0_34.exe AND Netgear A6210_v1_0_0_34-SA.exe Wifi adapter software? Both versions downloaded together for the Netgear A6210 Wifi Adapter. I'm not sure which one to use to install my Adapter.
Solved! Go to Solution.
Model: A6210|AC1200 High Gain Antenna WiFi USB Adapter
Message 1 of 3
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-27
05:05 AM
2016-06-27
05:05 AM
Thanks for the reply. I presumed the "-SA" version was the version with the Genie and installed the other version. It all seems to install and work just fine with no problem.
Message 3 of 3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-19
03:52 PM
2016-06-19
03:52 PM
Re: Netgear Wifi Adapter Software
One is just a free standing driver. The other one is Suite including Genie. Only using driver alone is much less troublesome. You can try both and
see it for yourself if in doubt.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-27
05:05 AM
2016-06-27
05:05 AM
Message 3 of 3
Announcements
