- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, I paid 60 dollars for this, lol.
I have the latest drivers, etc.
When I try to download ANY game on Steam, it says that the file is corrupt, etc.
Verifying the integrity of the game cache will NOT work.
Please help!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
- Mark as New
- Bookmark
- Subscribe
- Permalink
minions08 wrote: Have you tried to download using a different computer?
It's not my computer.
I tried a Linksys usb adapter, it downloaded games perfectly fine.
However, the netgear one is fast, so please! 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@chiruno09 wrote:Hi!
I read this on the Steam discussion forums also (perhaps it was you). I shall try directly connecting and report back. This issue is 100% repeatable with my A6210 and Steam downloads.
Cheers,
A
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.I read this on the Steam discussion forums also (perhaps it was you). I shall try directly connecting and report back. This issue is 100% repeatable with my A6210 and Steam downloads.
Cheers,
A
Just reporting back: Made no difference to my problem 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Just to verify if the computer you are using is on Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi aloonj,
Please check your inbox.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this issue now with the latest 10.0.34 drivers, for Windows 10 Pro.
This adapter is useless. Have had nothing but trouble with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, i've got the same trouble when downloading games on Steam, did you find the solution??
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only solution was to use another method of connecting, avoiding the netgear adapter.
I have a support case open with Netgear and they are working on trying to recreate the issue, so fingers crossed.
By chance are those with corrupted download problems all in the UK? On Virgin? Using a Superhub?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No i'm in France, and i'm not using a superhub, I just use their adapter 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nobody has got the solution??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please Netgear, I really need a fix for this now, it's getting so annoying and I can't download anything on Steam.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try switching to 2.4Ghz from 5Ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router has only 2.4ghz, can't do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi aloonj,
Do you have any updates from the support team?
Hi rafitamolin,
Do you have other devices that can performs well with steam download?
How far is the computer(with A6210) from the router?
Try changing channels of the 2.4Ghz as it might be a network interference with other wireless network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Support did some testing to try and recreate my issues and decided that the issue was interferance on 5Ghz. I swapped to 2.4Ghz and seemed much better..
However, I have tested alternate WiFi adapters at 5Ghz from same location and have no issues, so I am not fully convinced the problem lies with interference in my home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I spoke too soon!
Prompted by this latest forum post, I decided to try downloading again via Steam now that I am permanently on 2.4Ghz, but no, it has once again stopped mid download, I keep re-trying and eventually Steam reports the download is corrupt.
I will reopen my case and inform support.
[EDIT]
It seems my case has been closed and I cannot re-open it. At this point I think it will just be easier buying an alternate adapter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi aloonj,
I will check again on your case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I also have this problem and would like to know any progress on this issue.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi TilfeldigBruker,
Engineers are still checking on this issue. I will provide update if there are any feedback.
