× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Unable to connect wifi extender to router
Dcfay
Follower
Looking for,some help have tried unsuccessfully to install N300 wi if range extender onto my ac1200 router. Are they not compatible? There is no WPS button on the router, and I can't seem to,get it to connect to my router.
Message 1 of 3
Re: Unable to connect wifi extender to router
What are these devices? AC1200 and N300 are wifi speed indicators. They are not Netgear model numbers. Look on the side for those.
What do you mean by "install N300 [wifi] range extender onto my ac1200 router"?
You have posted your mesage in the WiFi Adapters section of thbis forum. Does that mean that one of these things as a WiFi USB Adapter?
Message 2 of 3
Guru
@michaelkenward is correct - Model numbers (including manufacturer if the router isn't Netgear's) are needed for us to help.
Message 3 of 3
Discussion stats
  • 2 replies
  • 508 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
