× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
W9CE 3001
Jonesarob
W9CE 3001
Hello, is there an eqivialent to the netgear wireless internet adappter WNCE 3001? I wish to connect a CCTV system to the internat via the router. Therefore looking to find an adapter (plug & play), ie with no drivers (CD) to set up.
Many thanks in advance.
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: W9CE 3001
Hi Jonesarob,
We only have the following wireless adapters without drivers needed for installation.
WNCE2001
WNCE3001
WNCE4004
Message 4 of 5
All Replies
Re: W9CE 3001
That's not how wifi adapters work. They need software and drivers.
If you already own a CCTV system, ask the makers how you can connect it to wifi and the Internet.
If it can connect via Ethernet then you could try this:
Powerline Networking | Powerline Ethernet | NETGEAR
Message 2 of 5
Jonesarob
Re: W9CE 3001
Thank you for reply, though as I understand the W9CE 3001, did not have a driver.  It was confirgued to your router direct, then was then inserted into the device. which then connected back to the router via wifi. Therefore no need for down loading drivers. Therefore was asking is there anything out there that is similar.
Message 3 of 5
JamesGL
Master
Re: W9CE 3001
Hi Jonesarob,
WNCE2001
WNCE3001
WNCE4004
Message 4 of 5
JamesGL
Master
Re: W9CE 3001
Hi Jonesarob,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1920 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
