- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNA1100 N150 disconnect at random interval
- Mark as New
- Bookmark
- Subscribe
- Permalink
My WNA1100 USB adapter disconnect at random -- sometimes every few minutes and sometimes, say, once a day. I am using this on Windows 7 Desktop PC and have the latest software for this device. The problem is solved temporarily with (1) disconnect and reconnect the device from USB port, OR (2) in Windows Device Manager, disable and then re-enable this device. Sometimes this 'disconnection' occurs every few minutes and sometimes the device would work find for full day. I have tried using this device on different USB slots and two different PCs with same result. Is there a solution or workaround to this erratic behavious?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @nksaini
Welcome to NETGEAR Community!
Please follow the steps below:
- Open Device Manager > Network Adapters
- Select NETGEAR WNA1100
- Right-click then select Properties
- Under Power Management Tab, disable "Allow the Computer to turn off this device..."
Here is the link for the latest driver WNA1100 Software Version 2.2.0.1
Blanca
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @nksaini
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNA1100 N150 disconnect at random interval
I will follow the steps and see if this resolves the issue. I will post the result here after 2-3 days.
Thanks,
nksaini
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Blanca_O,
It appears that after following the steps suggested by you, i.e. after disabling "Allow the Computer to turn off this device..." in Properties dialogue box of my Netgear WNA1100 Network Adapter, the problem of disconnection is solved. In the past 2-3 days I have not experienced disconnection of the adapter.
Thaks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
