× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNA3100M - Does it support 5ghz, if so how do i switch to it?
Niclas_sql
Follower
 - Gateway Version
      Mint 17.2
I would like to know if I can use 5GHz with my WNA3100M, and if so, how do I use it?
I was on my gateway because I wanted to change the channel. But then I noticed, that when I clicked on the 5GHz access point, and its speed, it was way faster, than the 2.4GHz one.
Model: WNA3100M|N300 Wireless Mini USB Adapter
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: WNA3100M - Does it support 5ghz, if so how do i switch to it?
Hi @Niclas_sql
Welcome to NETGEAR Community!
WNA3100M is not a dual band adapter. It can only detect 2.4GHz WiFi network. To know more about this product, you may check this link WNA3100M Tech Specs
Blanca
Community Team
Message 2 of 3
All Replies
Blanca_O
NETGEAR Moderator
Hi @Niclas_sql
Blanca
Community Team
Message 2 of 3
There is a manual for the WNA3100M somewhere at the end of this link:
>>>> WNA3100M | Product | Support | NETGEAR <<<<
See the specifications there.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5332 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
