- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNCE3001 keeps connecting for a second then becomes limited.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed the instructions, I got to the setup page, entered everthing, and in the last review step, it just says that the page is unavailable on chrome. The light is solid green. which I guess means it should be working. However, the ethernet connection says "Limited" and every 5 seconds it would connect for a split second then goes back to "Limited" as if it keeps disconnecting every 5 seconds. I reset it a few times and set it up by using different Wi-Fi connections and still the same result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNCE3001 keeps connecting for a second then becomes limited.
Hi @Dafor,
How far is the adapter from the router? Can you check if the firmware is the latest one? If not, you may check the link below for the firmware.
http://downloadcenter.netgear.com/en/product/WNCE3001#searchResults
JamesGL
Community Team
