- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDA 3100 v.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
WNDA 3100 v.3
The question is - has v.3 significant changes in hardware and firmware? I mean, for examle, if v.2 worked with TV Panasonic, do v.3 will work with it too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Hi @Vadim_,
Welcome to Community!
These units are running on different driver versions. Not necessarily that if v.2 works with Panasonic then the v.3 should work as well. It depends on the software/driver if the said feature is available.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Hi!
Thank you!
Before I read your answer, I tried v.3 with Panasonic TX-PR42UT30. It doesn't work with this TV.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Today I tried v.2 with TX-PR42UT30 - it doesn't work too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Is it possible to re program WNDA3100 V3 to V2 like serial number 2D4 as written below ?:
Note: You will need a WNDA3100v2 with serial number prefix of "2D4" to be compatible with the Panasonic TVs.
Thanks in advance
rs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Hi Roberto72,
It is not possible to reprogram the V3 to V2. These are two different versions with different drivers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Hi Roberto I have de same problem. Have you solve it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA 3100 v.3
Hi valter,
Only the v2 will work with Panasonic. The v3 will no support panasonic.
