- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDA3100V3 BSOD Security Check Error with disconnect and reconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every time my Netgear WNDA3100V3 USB WIFI adapter disconnects and then reconnects to the internet, my computer shuts down and displays the BSOD (blue screen of death) that says the stop code. "Kernel Security Check Error" and tells me to go to windows.com/stopcode and find an answer? Well I have uninstalled and reinstalled and made sure my computer and the adapter are updated. Nothing works. This happens many times a day!
Windows 10 Pro
ASUS M5A78L-M USB3
AMD FX 6300
64 bit
8 GB ram
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA3100V3 BSOD Security Check Error with disconnect and reconnects
Hi Fixitplease,
If you disconnect the adapter, does the computer still goes on BSOD?
If you have another computer, try installing the adapter and check if the same issue. Try cleaning as well the registry of your computer(Check microsoft).
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I disconnect it from the computer and don't plug it back in, my computer is fine. But if I plug it back in in connects the internet, then I get the BSOD. Also, if I lose the wifi signal and it reconnects by itself I get the BSOD.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Fixitplease,
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have uninstalled using Revo Uninstaller to completely remove it from my system and tried to install and uninstall and use 3 of the drivers on the Netgear website. Nothing seems to work and I have since installed a Tp-link Pci wifi card and I have had zero problems since. I believe the Netgear device is not compatible with Windows 10 Pro/My Computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Fixitplease,
Please check your inbox.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
We are receiving Bluescreen with this Adapter quite often too. 3-4 times a day... Details below
tcpip.sys 15f665
Windows 10 64 bit
Netgear WNDA3100V3 N600
ntoskrnl.exe
