- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDA4100 error on startup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Running Vista Home on Dell PC. Using Netgear N900 WiFi Dual Band USB adapter. Getting following error in startup:
'WNDA4100 Genie MFC Application has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
I am connected to the router. Not sure what the error means, and would like to fix whatever is wrong. Any help would be appreciated. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi bonnier243,
Please uninstall the genie utility of WNDA4100 and check if it has the same error.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi bonnier243,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDA4100 error on startup
How does one uninstall the Genie function but still maintain the ability to use the USB Wireless Connection. It seems I have only been able to uninstall the entire software suite thus far
- Mark as New
- Bookmark
- Subscribe
- Permalink
The genie is just a software you can use to connect to the network. If no genie, you can still use the windows utility to connect.
