- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi adapter A6100 help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi adapter A6100 help
You put you're trying to connect to a netgear modem. If its a modem, there should be a router as well or at least it be a combo device. More info here will help. What netgear router are you conneting to? Firmware on it?
What driver are you using for the adapter? Have you updated it recently?
https://www.netgear.com/support/product/A6100.aspx
have you tried uninstalling and then reinstalling?
You can also connect via the windows network manager utility. Have you tried this? Or went in through this to forget the old settings?
The link I gave you for the support site also has manual, installation guides, and troubleshooting. have you looked at that info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
While doing the uninstall try following this procedure:
1. uninstall driver and software
2. unplug the usb device
3. reboot the computer
4. install the driver (and software if you prefer, you can just install the stand alone drive and let windows manage the software if you prefer)
5. plug the usb device in.
Did you do it this route?
If you log into your router (which is what?), does it show on the connected devices page?
All your other devices are still working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would do it the way I suggest. Also don't use the cd. download the software from netgear's support site I linked to. Just use that.
You don't put what router you're using so its hard to tell you where your connected pages would be. Its manual should have it. But if you can log into the router from the computer running the A6100, its working. Just something is a slighly off.
Try the reinstall and reboot your router as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Frantelle wrote:
The problem is though my internet settings is saying no internet, secured.
Is that in Windows?
My first guess is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
