- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wireless Ping Spikes - A7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Recently I've started expirencing random ping spikes with my Netgear A7000 adapter. I have reinstalled the software, as well as tried older versions of it to no avail. I have found a solution- disabiling WLAN Auto Config in it's settings via netsh, however this is a very messy solution and I shouldn't have to do this on a production unit. Any ideas on how to fix this on a more permananent basis?
~RKarim
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wireless Ping Spikes - A7000
If you are running Windows 10, Disable the RunSwUSB service, reboot.
This MAY help you with ping spikes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To tell the trurth, junk the device. Buy something different.
Write it off as a bad purchase.
I bought it and now only use it as a backup device (since I bought it)
Has never worked from day 1 under Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are something Directional edimax ew-7811dac
Cheap, just works, but they do burn out over the months pushing 100GB's.
I do 400GB per month over about 700 meters, 5G, remote backup nightly.
I was hoping the A7000 would be long lasting, but I'm stocking up on the Edi's. Die/replace/forget until it dies.
At $27 it's way cheaper than I paid for the A7000 and the time to relises this is pointless.
Only have to google A7000 for issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
8-9 months replacement, not the best thing, but it works for the Edimax.
Plus I'm sure I push it beyond the design spec's, but Netgear has the A7000 that doesn't even work?
So what gives Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How did fix it?
Bet you will back tomorrow....
Speed and throughtput are 2 different things.
Heck I would be using Aruba gear if I could.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry if you seem it toxic.....
I work in IT so we can seem direct at times.
We don't try to be like that and it may come across like that.
Sorry
- Mark as New
- Bookmark
- Subscribe
- Permalink
You were being overly toxic and you know it. It was by intention. You did the following:
1) Attempted to show-off your technical knowledge (and failed miserably, mind you).
2) Said "bet you will be back here tommorow" and made other toxic comments regarding this company's product on their own forum, when a simple "this is a bad product- I had a bad time" would have sufficied.
None of those things were being "direct" as you so eloquently put it. This message is an example of being direct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Simple Question....
Did you Get to A7000 Working under Windows 10?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I said see you back tomorrow or 30 mins later...
Only have to Google the issues with a A7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
First issue I've had in 8 months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll wait for you reply on it working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Who would have thought, you find Trolls on a support fourm.
No wonder IT people don't like trying to help others for FREE, that would cost $70 an hour otherwise.
Give Up, case closed, on your own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
LOL Everyone that owns a A7000 is laughing at you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Must have, I'm out the door of MSY tomorrow when they open for EdiMax that works
