× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
netgrar nighthawk ac1900
richard105
Follower
I purchased a netgear wifi adapter NightHawk AC1900.  I was instructed not to plug in the device into the usb until the installation CD was run.  I have no external or internal cd drive for PC (only a mac, but it does not work with the PC).  So, I got a long blue ethernet cable and plugged it into the modem across the room. I clicked the download button, but I don't know if it is installed.  How do I know?  I hesitate to go any further because of the warning on the netgear hardware piece.  I always used a mac, and my office had IT people available...so I never bothered to learn how to do such tasks on the PC.  Now I am retired and up the creek.
 I contacted support and now and reaching out to the community.
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: netgrar nighthawk ac1900
Hi @richard105
Welcome to NETGEAR Community!
Kindly download the driver from this link https://www.netgear.com/support/product/A7000.aspx#download
Once done, open the file, run the .exe file and follow the onscreen instruction.
Blanca
Community Team
Message 3 of 3
All Replies
Guru
You must mean the A7000 adapter.  I'm moving your post to the correct forum for wifi adapters.
You can try contacting Netgear support via my.netgear.com.
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @richard105
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2496 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
