× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
which product do I need to add optional wifi to an ethernet modem?
PennyPlus
I am happy with my ethernet connection, but occasionally I would like to switch wifi on.  Which is the cheapest product that will do this?
Message 1 of 6
Accepted Solutions
AlvaroIsaac
Guide
Re: which product do I need to add optional wifi to an ethernet modem?
The cheapest way is FREE!  I did some research for you and found a nice how-to for turning your computer into a wireless hotspot.
How to Turn Your Windows PC Into a Wi-Fi Hotspot
Let me know if this helps.
Message 5 of 6
All Replies
TheEther
Guru
Assuming that all you have is a pure modem, then what you need is a Wi-Fi router (link).
Message 2 of 6
AlvaroIsaac
Guide
To best answer this question, it would help to know more information regarding your ethernet modem.  For example, if it is a simple modem, then you need a router.  But if it is a combination modem router, then you can simply add a wireless access point. You could also use a USB Wifi adapter in a host computer to set up shared Wifi, but this is more complicated.
Message 3 of 6
PennyPlus
I have entered the model of the router I have got above.  Can you recommend a USB wifi adapter that I can plug in to my computer?  You say it is complicated.  How can I find out how to do this?
Thanks for your time
Model: DG834|ADSL Firewall Gateway
Message 4 of 6
AlvaroIsaac
Guide
Message 5 of 6
PennyPlus
Thanks, this was really useful.  I went online and researched connectify for mac and found this link
http://apple.stackexchange.com/questions/38507/is-there-an-application-like-connectify-for-mac-os-x-...
It turns out I can already turn my computer into a wifi hotspot!
all the best,
Penny
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4644 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
