× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
wireless wifi
Ijustwanttoaskq
Follower
wireless wifi
jeez, I just want to ask a question. Why all the hoops? That wasn't the question. I hooked up the adapter, held the button for two (2) seconds, but then it says I need to press the button on the wireless router, otherwise it times out and I have no connection. So I need that too? All I have is the Arris modem given to me by at&t.
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: wireless wifi
Hi Ijustwanttoaskq,
The button is the WPS. It will only work if the router has WPS button otherwise you should connect it manually using the Genie.
Message 2 of 3
All Replies
JamesGL
Master
Re: wireless wifi
Hi Ijustwanttoaskq,
Message 2 of 3
JamesGL
Master
Re: wireless wifi
Hi Ijustwanttoaskq,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3154 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
