× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
0 days remaining
Rafaz
Initiate
0 days remaining
Hi all, can someone help me with my router. I set the billing cycling for 4th Of each month. But no matter what I do I always get 0 days left on the data remaining information. I tried everything and it doesn’t work at all. Is it a bug? I’m using on EE and tried the same sim on one M1, and it works normally. Should I replace the router? Is anyone else having this problem? I have the latest firmware
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: 0 days remaining
Hi @Rafaz
Welcome to NETGEAR Community!
Have you tried resetting the router? If not, please do so.
May we please know the device SKU (MR1100-100xxx)? Kindly provide as well the firmware version.
Blanca
Community Team
Message 2 of 3
All Replies
Blanca_O
NETGEAR Moderator
Hi @Rafaz
Blanca
Community Team
Message 2 of 3
Rafaz
Initiate
Well, thank you for your response. I think it's better later than never.
I did reset, factory reset and well, nothing as I said before.
But at the end [not] thanks to your poor customer service (that was blaming my provider after transfer my calls 5 times) or this abandoned forum I end up taking the unity back as it was clearly faulty. The new unity came working fine and the days are counting normal, without I ever bothering my provider.
Thanks a lot guys for all this  marvellous support. 👎
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2831 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
