× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
2.4HZ ISSUE
Jasmine88
Follower
2.4HZ ISSUE
Hi All,
Would anyone know why 2.4Hz isn't working when trying to connect but the 5GHz does? It still works but the strength is weak it wont even load a 3min video? Is this common? Ive never had an extender before and haven't had an issue with it since I bought it 5 months ago!
Thank you
Jasmine
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: 2.4HZ ISSUE
1. what router do you have it connected to?
2. it worked fine before? What changed?
3. have you tried changing the 2.4ghz channel the router is broadcasting on?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 466 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
