- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2. Ex2700's on one router
- Mark as New
- Bookmark
- Subscribe
- Permalink
High I'm trying to connect 2 ex2700 to my router I can get them both to set up and work but after a few hours I can't connect to them with any device it keeps trying but not connecting
is it possible to have more than one extender connected. To my router
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2. Ex2700's on one router
Hi To666ny,
Are both your EX2700 connected to each other or the router? http://kb.netgear.com/app/answers/detail/a_id/24801/~/what-is-a-wireless-extender%3F
Which router are you using?
Also, how have you named your EX2700 SSID?
I look forward to hearing from you.
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
both connected to the router
the router is a sky one model number sr102 (in the UK )
they are my router name one finishing with _EXT and one with _CAB
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried connecting your devices to the EX2700 via ethernet?
How is the connection when placing the EX2700 near the router?
Can you also try factory resetting the router?
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Haven't tried via Ethernet or a factory reset ,I will try and let you know
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having a similar issue - two ex2700 extenders and a router. Is that feasible? What was the resolution if any? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi rw28658,
Yes, it's possible to pair multiple extenders to a router.
Please note, that it is not recommended to daisy chain the extenders:
"Range extenders are not designed to be daisy-chained. You can use multiple extenders but their main source of wireless connection must be the same. You cannot connect an extender to another extender's wireless network."
