× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
2 devices in the same network
teresarocha
Follower
Hi, i bought 2 devices of netgear EX6100 and i am trying to connect both under one network, because right now, i have my main wifi connection plus 4 different extension connections (2 and 5ghz) for each extender. Is it possible to add all of them under the same name network so only one wifi connection shows up
When i connect wifi? Thanks
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: 2 devices in the same network
Hello teresarocha
unfortunately no you can not do this with these extenders you will have to look into our business access points if you are looking for a system that connects your whole network as 1 wifi connection and hands you off to each ap.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2969 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
