× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
2 extenders won’t take router password
Lewisfamily999
Follower
I have 2 net gear extenders which worked fine until recently but now they say the password is incorrect. Have done factory resets, restarted WiFi, checked router password but nothing helps. Most of house is a black spot with no WiFi. Can anyone help? Please?
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: 2 extenders won’t take router password
what router are you connecting them to?
Are you setting them up using WPS, using the app, or using the installation assistant?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 301 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
