× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
6150v2
weemac
Tutor
6150v2
Was working fine, but moved it to a new location and now all I get is a solid green power light and nothing else, no matter how many times I reset I still get nothing, do
you think it has died
Message 1 of 9
Guru
Re: 6150v2
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 9
weemac
Tutor
Re: 6150v2
Thanks for trying to help
I get nothing when I try WPS
When I do a reset all I get is a constant orange power light and nothing else
Message 3 of 9
Guru
Re: 6150v2
If the power light is solid orange/amber, its likely something is corrupt or failed in the boot process.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 4 of 9
weemac
Tutor
Re: 6150v2
Thanks, I will give it a try and get back to you
Message 5 of 9
weemac
Tutor
Re: 6150v2
Just noticed that's instructions for a router, not an extender
Message 6 of 9
Guru
Re: 6150v2
They are for a router but it works on extenders as well. If you watched the video, the user does it on an extender.
Message 7 of 9
weemac
Tutor
Re: 6150v2
sorry but I don't get this, just cant get my head around the TFTP, just don't seem to be able to get the one in the video, but everything else is straight forward
Message 8 of 9
beetecaste
Re: 6150v2
Thanks for trying to help.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 518 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
