Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC 750 firmware upgrade - now cannot login
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-04
12:21 PM
2019-02-04
12:21 PM
Regards:
I just bought a Wifi range extender AC750 and when I try to connect a device it asks for the password of the router, I put the number with which I connect my device and it tells me the wrong password and I can not enter the page that indicates the instructions because that has to be for the extension and asks for the password that tells me that is the wrong.
Thanks
Model: EX7500|AC2200 Nighthawk X4S Tri Band Wall Plug WiFi Range Extender
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-07
03:39 PM
2019-02-07
03:39 PM
Re: AC 750 firmware upgrade - now cannot login
Hi Luis0505 - Hard reset the extender by pressing on the small black button with a pin and join the NETGEAR_EXT wifi network. After you connect to it, browse to www.mywifiext.net and follow the setup instructions.
~Christian
Message 2 of 2
Announcements
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
