×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AC1200 DB WiFi Range Extender and odd IP Address 165.165.165.165
Kehrer1701
Was looking at my main wifi router page and notice that when my extender is running, I have an ODD IP attached 165.165.165.165 that says its Telkom based in South Africa. I know none of my devices are based in SA so this has to be coming from the wifi extender itself. Just not sure if this is malicious or part of the extender.  Any thoughts appreciated.
Message 1 of 3
Guru
Re: AC1200 DB WiFi Range Extender and odd IP Address 165.165.165.165
What extender do you have? AC1200 is a speed, not a model.
Easy check is to disconnect the extender and see if that ip address is still showing. (might be a device connected to the extender so that isn't a for certain check)
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Kehrer1701
Main router: C3700-100NAS
Extender: EX6110
I've confirmed this 165xxx is showing up only when my extender is connected and it says it's connected to my main wifi router (which it shows under connected devices) and connected to the 2.4GHz band.
What's funny, I'm not extending the 2.4 Ghz band either, so it must be the IP of something in the extender itself?
Just very odd, since that IP shows a South African address.
I'm going to reset that extender, in case something went awry during setup.
Oddly, the device names shows properly attached on my main cable modem under 5Ghz band.
While I'm not sure sure it's malicious, I don't know what is the cause of this IP
I find an old page with similar issue here:
https://www.dcurbanmom.com/jforum/posts/list/984208.page
https://www.findip-address.com/165.165.165.165
Message 3 of 3
Discussion stats
  • 2 replies
  • 444 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
