Reply
Highlighted
AC1200 Dual Band WiFi Extender [can I reconfigure in a different town]
Message 1 of 5
Accepted Solutions
Highlighted
Virtuoso
Re: AC1200 Dual Band WiFi Extender [can I reconfigure in a different town]
You should be able to reconfigure the extender when you take it to a new LAN location.
I think that if both your locations employ WPS then it should be as simple as using WPS at each location.
But yes, you should be able to take the extender from one LAN location and move the extender to another LAN location and after reconfiguring the extender. then it will operate on the new LAN.
If you do not reconfigure the extender, then it will not operate properly at the new LAN location.
Message 4 of 5
All Replies
Highlighted
Virtuoso
Is that a trick question?
What exactly does it mean and what exactly do you intend to do with it?
Message 2 of 5
Highlighted
Apologies, not a trick question. I want to configure and connect to the Wifi in my house (as a test run) and then take the extender to another location and reconfigure there. Can I continually reconfigure? Hope that's clear.
Message 3 of 5
Highlighted
Virtuoso
Message 4 of 5
Highlighted
Thanks for the advice
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 488 views
  • 0 kudos
  • 2 in conversation
Announcements
