Orbi WiFi 7 RBE973
Reply
AC1200 WiFi
JUSTWONDERINGWH
AC1200 WiFi
AC1200. It is all set up with all green lights displaying. I can't see it displayed on the list of network connections. Any thoughts? Thanks
Message 1 of 7
Guru
Re: AC1200 WiFi
What do you actually have? AC1200 is a speed and not a model.
Some extenders are mesh. Meaning they use the same ssid as the router so devices can roam between router---extender based off their own roaming protocol.
Message 2 of 7
JUSTWONDERINGWH
Re: AC1200 WiFi
The Box displays AC1200 WiFi mesh extender
Message 3 of 7
Guru
Re: AC1200 WiFi
What's on the label for the device?
Regardless. It is a mesh device. So it's default will have the same SSID as the router.
You can disable that function if you'd like
Message 4 of 7
JUSTWONDERINGWH
Re: AC1200 WiFi
How do I determine if this is functioning correctly. If I only show my home WiFi and not the extender. I’m not sure if the “mesh” does this? Thanks
Message 5 of 7
JUSTWONDERINGWH
Re: AC1200 WiFi
Sorry, I just found it on the bottom of the box. EX6150-100NAS.
Message 6 of 7
Guru
Re: AC1200 WiFi
This is exactly what "mesh" does.
It uses the exact same ssid as your router and lets devices roam between the 2 networks as well as their 2.4ghz/5ghz band as needed.
You can log into the extender and check to see if devices are connected to it. Log into your router and look at its attached devices page (or equivelent) and it should have the IP address for your extender. That shows that its connected but you can use that ip address to log into the extender and check its status and attached devices. Or you can use the app.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 736 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
