× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC1750 wont connect, SSID not found, can it be that it is a Canadian model and I am in the USA
ibmemployee
Follower
I am trying to setup the AC1750, when I try to connect my android phone it can not find NETGEAR_EXT.  NETGEAR_EXT is not listed in the list of devices connected to my Belkin router when I look at  my dashboard.  I have tryed using the Nighthawk app and connecting the AC1750 directly to my Windows Computer.
Is it possible that the problem is due to the fact that the unit was purchased in Canada and I am trying to use it in the USA?
Message 1 of 2
Guru
Re: AC1750 wont connect, SSID not found, can it be that it is a Canadian model and I am in the USA
First off, AC1750 is a speed, not a model.
From you're post you're attempting to connect an extender? Because you posted in the app section and not extender section.
If so, which model?
What router are you trying to connect it to?
Are you trying to installing it using wps or using the installation assistant?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 272 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
