× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC1750
Jeffcv
Follower
AC1750
I have a AC1750 Mesh Extender. I recently replace my older router with a new one from Xfinity. Having trouble setting up/connecting to router. Tried using Nighthawk with no luck. Any suggestions? Jeff
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 2
Guru
Re: AC1750
Did you try using the installation assistant?
I'd factory reset the extender (push and hold reset for 7-15 seconds while powered on), then hardwire a pc/laptop into the extender (disable the pc/laptops wifi) and try setting it up using the installation assistant.
what xfinity router is it?
Message 2 of 2
Discussion stats
  • 1 reply
  • 229 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
