× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC1900 Extender devices connect but no internet
railcars
I have a AC1900 EV7000 extender that is connected to my netgear C6250 cablemodem/router.  No issues with connecting between the extender and the device however when i connect to the extended SSID network i get no internet.  Please help as i have spent alot of hours and have got no where.
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 7
LordPurple
Star
Re: AC1900 Extender devices connect but no internet
Railcars - if you just updated the extender's firmware to V1.0.1.78_1.0.140 - that would be your problem.  As reported in other threads (see index) this firmware seems to break EX7000 extenders, at least many of them - including mine.  Suggest downgrading the firmware to 1.0.0.66, that worked for me.
Message 2 of 7
railcars
Thanks. I upgraded the firmware but don’t know what version. Will look tonight and try. Thanks.
Model: EX7000|AC1900 WiFi Range Extender
Message 3 of 7
railcars
Are you running as extender or access point. I am running as extender.
Message 4 of 7
LordPurple
Star
I am running as an extender, and the new firmware definitely broke it.
Message 5 of 7
pacoinconn
I'm very glad I found this thread.  We've been having the same problem with our two EX7000 extenders.  Both are being run as access points (ethernet cable to Netgear managed switch to Asus routher which assigns IP addresses and is connected to cable modem).
Both EX7000 are on firmware version V1.0.1.78_1.0.140.
Very frustrating.  WIll try to revert back to the previous firmware.  Hope Netgear fixes this soon.
Message 6 of 7
Bendeego
Guide
Hi,I had a similar problem where after updating firmware I could not connect my iPad and smart tv to the extender,
i solved my problem by changing the security,,starting with none and finishing with TKIP setting ,,all now connect ,,
hope this helps
Regards
PeterH
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2137 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
