- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 WiFi Mesh Extender - DHCP Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hardware Version: EX6410
Firmware Version: V1.0.0.124
Hi,
Recently bought one of these and have the latest firmware running. The 6410 is running in extender mode and works fine .... most of the time.
Every few weeks it decides to stop passing through the DHCP request to the clients. Nothing wrong with the main router. When giving clients a static IP address and connecting to the extender works fine and also when connecting to the main router with the same clients passes the DHCP address with no problems.
One by one the same starts happening to other clients and I end up having to put static IP's to each device which isn't great.
Any ideas ? Thanks in advance
Cheers, Yasin
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Product : EX6470
Firmware : v1.0.3.30
Same problem as reported but I found a possible cause.
Sometimes DHCP request sent thru the extender doesn't succeed.
In this cases I saw that there's always at least a duplicated IP in the connected devices list of the extender interface.
It seems that old ip addresses are kept in memory (how many time ?) and cause an issue if there's a new dhcp request for the same device while its old ip is already taken by another device.
I explain :
- 1st state :e. :
device A ip = x.x.x.22
device B x.x.x.32 - 2nd state :
device A no more connected and ip expired
device B renews its ip and get x.x.x.22
I the extender memory we see both device A an B with the same ip (x.x.x.22), it's a bug in the ex6470 ...
At least, as soon as a new ip is catched, other devices with the same ip should be remove from the connected list.
While device A is still present in the list, dhcp requests don't work properly thru the extender.
I only found 2 way to solve this manually :
- Restart the extender to empty its connected devices list (very impacting solution, not smart at all)
- Force my dhcp server to give a new specific ip to the mac address of the impacted device (it works immediately)
If netgear could solve with problem in a new micro code update, it would be nice.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1900 WiFi Mesh Extender - DHCP Issue
dhcp is handled by the router with the extender just acting as an intermediary. More than likely lease times are expiring and the router isn't recognizing it because of the extender in the middle.
Does the extender have a static route setup? or just the devices connecting to the extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
No static routes set-up on the extender - just the clients which fail I'm setting up manually.
I don't think there is any issue with the main router. The same devices which can't get a DHCP address from the extender can get one directly from the router without any problems.
Yasin
- Mark as New
- Bookmark
- Subscribe
- Permalink
What router is it connected to?
Did you set it up with wps or using the installation assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
TalkTalk Huawei Super Router HG633
I set it up using the install assistant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Product : EX6470
I explain :
- 1st state :e. :
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me it's not solved.
I gave 2 workarounds for the problem, but one needs some technical knowledge and the other, stop/start the extender, is just not an acceptable solution.
The right solution would be a firmware update from netgear to remove the noted behavior.
