× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC2200 nighthawk extender.
K9cop1142
Ac2200 is setup if power is disconnected will I have to go back to setup and find and install the extender again, asking in case I want to move extender .
Message 1 of 17
Accepted Solutions
Guru
Re: AC2200 nighthawk extender.
its actually done by the router. The extender has to use the same channel the router is on so changing the wireless channel, changes which one the extender uses.
What extender is it? AC2200 is a speed.
What firmware is on it?
Waht router is it connecting to?
Message 6 of 17
All Replies
Guru
if you unplug it and plug it in elsewhere, it should retain its settings and be able to autoconnect.
Message 2 of 17
K9cop1142
Hmm,it did not seem to do that for me but I will try it again ,is there anything in the settings to check for auto connect.
Message 3 of 17
Guru
auto connect back to the router or the devices to the extender?
Reason I ask that is if you move it somewhere where the service is sketchy, something is blocking wifi (think things in walls like hvac), or its just out of range, then it won't/can't connect.
Message 4 of 17
K9cop1142
I was having a problem with it connecting back to router, is thgere a way to change channels on the extender so to get which ever is better or is that done by extender.
Message 5 of 17
Guru
Message 6 of 17
K9cop1142
model ex7700
  • Firmware Version: V1.0.0.210
SageMCOM 5260CV router
Message 7 of 17
Guru
I've seen of several people that had issues with the .210 firmware. I'd try downgrading it to the .206 firmware version and then disable auto-updates. skip the .210 version.
Message 8 of 17
K9cop1142
which firmware is better and is there installation steps now that I cannot access via phone
Message 9 of 17
Guru
the .206 has been more reliable from what I've seen on the forums.
The support site has the manual that goes over the install process.
EX7700 | Nighthawk WiFi Range Extender | NETGEAR Support
Message 10 of 17
K9cop1142
I have loaded the 206 and still cannot get the app on my android to work , looks like I'm going to have to stick with windows 10 to access.
Message 11 of 17
K9cop1142
I also tried the app on another android phone and it will not connect to the extender.it has to be the application
Message 12 of 17
Guru
What app are you having issues with?
I read back through the conversation and it was more about it auto connecting. so I'm a bit confused at the turn in conversation and whats going on exactly
Message 13 of 17
K9cop1142
Yes I asked if I disconnected the power to move extender if it would auto connect because I had a problem with it connecting, but after inial setup the nighthawk app will not connect if I click anywhere connect it has local connection available but it will not auto find the extender.
Message 14 of 17
Guru
But it connects and works fine (other than the app)?
And you can see/view it through the browser?
Message 15 of 17
K9cop1142
Yes thats correct. all 3 lights are on extender
Message 16 of 17
Guru
Maybe its an issue with the app. I wouldn't worry about
Message 17 of 17
Discussion stats
  • 16 replies
  • 2069 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
