- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC750 Range Extender Model EX3700 Can I get smart phone to switch automatically?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I walk close to the extender my smart phone does not automatically switch to the extender for its signal. I have to manually tell it to switch. Is there a way to automate this switch? And then to have my smart phone switch back to the main household wifi router when I get closer to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC750 Range Extender Model EX3700 Can I get smart phone to switch automatically?
Its usually devices specific until you upgrade to the mesh systems. They (mesh) dynamically move you from one to the next based upon signal strength. There's other systems that move your device around based on rssi strength but its usually business grade networking equipment.
There are apps that automate the process for each device. I've never used one as I use a mesh setup but just a quick google pointed to this article on gizmodo with some advice. Its a bit dated so there might be other apps available now on IOS that are more intuitive.
https://gizmodo.com/how-to-stay-on-the-strongest-wi-fi-network-at-all-times-1788378454
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
