- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC750 Wi-Fi range extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
My WiFi extender works well once connected, but every day I have to cycle power to get it to connect to my device. It asks me for my WEP password, but won't take it when I enter it. Once I cycle power and it reboots, it connects fine. Setup shows it is connected properly, and I've updated to the latest version firmware. Any suggestions to resolve would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM,
Thanks for all the help. As soon as I get my adaptor, I'll reload the firmware and do setup again.
Reggae
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC750 Wi-Fi range extender
Hello Reggae
Is the extender a littler to far away from the router and it drops signal? If not have you tried to factory reset he extender and go threw setup again.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
The extender is in range per the indicators, and does not drop the signal. Works great when connected. It just requires a power cycle for me to connect every day or two. I setup the Wifi extender via a Wifi connection. Net gear said I should do setup again using a hard wire Ethernet connection. Apparently the wifi connection is prone to interference that can corrupt the firmware. I guess I'll have to set up again using a hard wire connection to the extender per your and netgear support advice. Thanks for the reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reggae
Let me know if that resolves the issue or not.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Darrell M,
I have a Macbook pro laptop. once I get a thunderbolt to ethernet adaptor and shut off my wifi connection at my laptop, do i just do the ethernet connection between the laptop and the extender, or do i need to connect through my router (e.g. laptop to router, and router to extender)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reggae
To setup the extender you would want to plug directly into it.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM,
Reggae
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM,
Just reinstalled the firmware recently using a hard wired ethernet connection, the extender works well with all devices now. I also found out that there is a compatibility issue running netgear's genie app for my MAC running OSX El Capitan. I closed the app prior to reflashing the firmware, so not sure if the reflash of the firmware, or shutting down the genie app fixed my issue. I was advised to delete the genie app from my computer until apple and netgear resolve the issue. Thanks for all your help through my issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reggae
Thanks for that tip if that was what caused the issue.
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
