× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC750 WiFi Range Extender
dmcloughlin69
Follower
Hi All
I'd like my extender to be just that, an extender but the way it appears to be setup as default is a different connection.
Here is my little quandry.
I've 2 rooms. In each room I have speakers. I use 2 Chromecast Audio to connect to the 2 speakers.
It appears both have to be connected to the same connection point for them work as a group.  At the moment this works as my wifi range reaches both speakers but I want to extend to a 3rd speaker which is too far away from thw main router.
When I connect to the extender and then sit near the main router, this appears to disrupt the signal. I must then switch my device to the main router.
I'd like my wifi signal  to be extended/boosted so my devices cannot tell the difference between each connection point and it works seamlessly.
Cheers
D
Model: EX3920|AC750 WiFi Range Extenders
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: AC750 WiFi Range Extender
You may need a mesh system like orbi for this.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 487 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
