× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC750
KeithCubz
Follower
AC750
I cannot get my Netgear Model EX3110 to connect to my Netgear AC1900 Model C7000v2 cable modem router. I followed the instructions exactly.
When I press the WPS button on the C7000, it does not light. Is something wrong with it?
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: AC750
have you tried installing it using the installation assistant?
Start back at factory. Push and hold reset for 7-15 seconds while the extender is powered on.
then install it using the assistant and NOT wps.
Message 2 of 2
Discussion stats
  • 1 reply
  • 338 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
