Orbi WiFi 7 RBE973
Reply
AP WG602 V2 -- Use of Point to Point Bridge with WNDR3700 Router
Roger_NG
Hi there,
I am using the WNDR3700 router which does not provide sufficient coverage. I buy a AP WG602V2 hoping to expand the wifi range. The AP has good range but could not access to internet.
Both MAC numbers are entered into each other admin page. The router is set at Repeater mode while AP at bridge (both point to point and repeating modes).
Could WG602 work as range expander along with router WNDR3700? If yes, how shall I configue it?
Thanks,
Roger
Message 1 of 4
jmizoguchi
Virtuoso
Re: AP WG602 V2 -- Use of Point to Point Bridge with WNDR3700 Router
should work.
one pointer is , repeat will only work in 54Mbps/WEP as well so may interest to get wn2000rpt or wn3000rpt extender instead 🙂
Message 2 of 4
Roger_NG
Thanks for response.
As the AP has point-to-point mode, could I use the router 3700 as repeater base and AP WG602 as point-to-point bridge or I have to use the AP as repeater client?
Thanks,
Roger
Message 3 of 4
jmizoguchi
Virtuoso
All will uses a same method 5MMbps/WEP
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4460 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
