htsebay
Jan 31, 2020Aspirant
ATT Fixed Wireless Internet - Access point
We live in a rural area, and are thinking about switching to ATT Fixed Wireless from DSL.
I had read from other users that the range for the equipment they supply is short, and to look into a access point.
Best Buy had recommended the NETGEAR - Nighthawk AC1900 Dual-Band Gigabit Mesh Capable Wi-Fi Range Extender
Is this product something others have experience with using with Fixed Wireless Internet?
1 Reply
- DexterJBNETGEAR Moderator
Hi htsebay, welcome to the community! The EX7000 is a wireless extender that is designed to work with most, if not all, wireless routers and gateways (modem-router combo). You can check with your ISP (AT&T, in this case) for compatibility but it shouldn't be an issue.
Dexter
